跳转到主内容
Sophix TAB-730g Speakers Replacement
你所需要的
  1. Sophix TAB-730g Speakers Replacement, Speakers: 步骤 1 中的图像 1,1
    • Remove the back panel of the tablet so that you can access the tablet’s motherboard.
    • First, using the #000 Phillips screwdriver, remove the screws located at the bottom of the tablet.
  2. Sophix TAB-730g Speakers Replacement: 步骤 2 中的图像 1,1
    • After you have removed the screws from the bottom of the tablet, you can now slide the cover off. To do this, place your hand on the panel and firmly slide the panel in the direction that the arrow indicates.
  3. Sophix TAB-730g Speakers Replacement: 步骤 3 中的图像 1,1
    • Next, find the wires that connect the speakers to the motherboard. (Follow the red marker indicated in the image.) To remove these, you will use the soldering iron.
  4. Sophix TAB-730g Speakers Replacement: 步骤 4 中的图像 1,1
    • Turn the device so that the speakers are at the top.
    • Locate the leads that connect the logic board to the speakers.
    • Starting from the left, you will use the solder iron to desolder the first four leads.
    • Now you are ready to remove the old, and insert the new speakers.
结论
JT Hiquet
于09/29/16注册
333 声望
创作了3篇指南
团队
IUPUI, Team 2-3, Harley Fall 2016 IUPUI, Team 2-3, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 171
