跳转到主内容
Sony ZS-RS60BT Repair Battery Replacement
你所需要的
  1. Sony ZS-RS60BT Repair Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sony ZS-RS60BT Repair Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate back panel.
    • Put firm downward pressure on the panel until it slides off.
  2. Sony ZS-RS60BT Repair Battery Replacement: 步骤 2 中的图像 1,1
    • If the batteries are corroded, it is recommended to wear gloves when removing the batteries.
    • From the positive side of the battery, push it to the negative side and lift up.
    • Repeat for each battery until the compartment is empty.
结论
Sarah Hamrin
于02/01/17注册
1 声望
创作了2篇指南
团队
Baylor, Team 8-2, Whitney Spring 2017 Baylor, Team 8-2, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G2
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 664
