跳转到主内容
Sony Xplod CDX-MP30 Power Supply Replacement
你所需要的
  1. Sony Xplod CDX-MP30 Power Supply Replacement, Front Panel: 步骤 1 中的图像 1,3 Sony Xplod CDX-MP30 Power Supply Replacement, Front Panel: 步骤 1 中的图像 2,3 Sony Xplod CDX-MP30 Power Supply Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Power Supply Replacement, Main Panels: 步骤 2 中的图像 1,2 Sony Xplod CDX-MP30 Power Supply Replacement, Main Panels: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    购买
  3. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 3 中的图像 1,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 3 中的图像 2,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Phillips #1 Screwdriver
    $5.49
    购买
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 4 中的图像 1,1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 5 中的图像 1,2 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    $5.49
    购买
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 6 中的图像 1,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 6 中的图像 2,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    $5.49
    购买
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 7 中的图像 1,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 7 中的图像 2,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 7 中的图像 3,3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 8 中的图像 1,2 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 8 中的图像 2,2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    $5.49
    购买
  10. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 10 中的图像 1,2 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    $5.49
    购买
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 11 中的图像 1,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 11 中的图像 2,3 Sony Xplod CDX-MP30 Power Supply Replacement: 步骤 11 中的图像 3,3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 Power Supply Replacement, Power Supply: 步骤 12 中的图像 1,2 Sony Xplod CDX-MP30 Power Supply Replacement, Power Supply: 步骤 12 中的图像 2,2
结论
2等其他人完成本指南。
Chao Chen
于10/04/11注册
79 声望
创作了5篇指南
团队
Cal Poly, Team 5-35, Amido Fall 2011 Cal Poly, Team 5-35, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G35
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 7,224
