跳转到主内容
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
你所需要的
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: 步骤 1 中的图像 1,3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: 步骤 1 中的图像 2,3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    购买
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 3 中的图像 1,3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 3 中的图像 2,3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 4 中的图像 1,3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 4 中的图像 2,3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 5 中的图像 2,2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: 步骤 6 中的图像 1,1
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
结论
Chao Chen
于10/04/11注册
79 声望
创作了5篇指南
团队
Cal Poly, Team 5-35, Amido Fall 2011 Cal Poly, Team 5-35, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G35
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 5,601
