跳转到主内容
Sony Xperia ZL Volume and Power Button Replacement
你所需要的
  1. Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: 步骤 1 中的图像 1,2 Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: 步骤 1 中的图像 2,2
    • Open the small cover on the bottom of the rear cover.
    • Peel back the sticker under the cover to reveal two screws.
    • Remove the two JIS #00 screws from the back of the phone.
  2. Sony Xperia ZL Volume and Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the six screws from the phone using a JIS #00 screwdriver.
  3. Sony Xperia ZL Volume and Power Button Replacement: 步骤 3 中的图像 1,1
    • Use a nylon spudger to disconnect the seven connectors.
    • Never use a metal spudger around the battery. Use plastic or nylon prying tools instead.
  4. Sony Xperia ZL Volume and Power Button Replacement: 步骤 4 中的图像 1,1
    • The last connector is located under the back sticker.
    • Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
  5. Sony Xperia ZL Volume and Power Button Replacement: 步骤 5 中的图像 1,1
    • Remove the camera assembly using an opening tool or spudger.
  6. Sony Xperia ZL Volume and Power Button Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard with an opening tool or spudger.
  7. Sony Xperia ZL Volume and Power Button Replacement: 步骤 7 中的图像 1,1
    • Remove the battery with a plastic opening tool or spudger.
    • The battery has adhesive tape that connects it to the phone which makes it difficult to pry out.
    • Never use metal prying tools on the battery. Be sure to use a plastic prying tool to avoid puncturing the battery.
  8. Sony Xperia ZL Volume and Power Button Replacement: 步骤 8 中的图像 1,1
    • Detach the plastic covering from the top side of the phone by hand.
  9. Sony Xperia ZL Volume and Power Button Replacement: 步骤 9 中的图像 1,1
    • Pry off the signal receptor and front camera using an opening tool or spudger.
    • The signal receptor has adhesive tape underneath so proceed with caution when prying.
  10. Sony Xperia ZL Volume and Power Button Replacement: 步骤 10 中的图像 1,1
    • Remove the volume and power button with an opening tool or spudger.
    • For replacement, this component comes as a whole. If the volume and power button do not work, they will need to be replaced together.
结论
另外一个人完成了本指南。
Liam Kanaley
于11/03/15注册
433 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 UMass Dartmouth, Team 1-7, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,071
