跳转到主内容
Sony Xperia ZL Battery Replacement
你所需要的
  1. Sony Xperia ZL Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the phone face down.
  2. Sony Xperia ZL Battery Replacement: 步骤 2 中的图像 1,1
    • At the bottom of the phone will be a cover that flips open. A sticker will be under and when the sticker is peeled back, two screws will be revealed. Use a JIS J00 screw head to unscrew.
  3. Sony Xperia ZL Battery Replacement: 步骤 3 中的图像 1,1
    • Once the two screws have been removed. Take the prying tool to pry off the back cover of the phone. Next take a JIS J00 screwhead and unscrew the 5 screws that are located in the photo.
  4. Sony Xperia ZL Battery Replacement: 步骤 4 中的图像 1,1
    • After the screws have been taken out, carefully disconnect the 7 indicated connectors using a small plastic opening tool or spudger.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  5. Sony Xperia ZL Battery Replacement: 步骤 5 中的图像 1,1
    • The last connector is located under the black sticker. Peel back the black sticker and disconnect the last connector.
  6. Sony Xperia ZL Battery Replacement: 步骤 6 中的图像 1,1
    • Once all the connectors have been disconnected. You will want to use a small prying tool to pry out the back camera and all its components from the phone.
  7. Sony Xperia ZL Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the electrical panel with a plastic opening tool.
  8. Sony Xperia ZL Battery Replacement: 步骤 8 中的图像 1,1
    • Take a small plastic prying tool and pry out the battery of the phone. The battery has adhesive tape that connects it to the phone which makes it difficult to pry out. Make sure to try prying from different angles of the battery.
    • Use a plastic prying tool when taking out the battery because any puncture within the battery could cause a fire.
结论
3等其他人完成本指南。
Liam Kanaley
于11/03/15注册
433 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 UMass Dartmouth, Team 1-7, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,726
