跳转到主内容
Sony Xperia Z5 Rear Camera Replacement
你所需要的
  1. Sony Xperia Z5 Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the edges on the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Sony Xperia Z5 Rear Camera Replacement: 步骤 2 中的图像 1,2 Sony Xperia Z5 Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
    • Pull up the suction handle to generate a gap.
    • Insert an opening pick into the gap to further separate the rear glass from the phone assembly.
    • The adhesive of the Xperia Z5 is fairly weak and it is possible to remove the rear glass without the use of an opening pick. In case you‘re having trouble you can have a peek at the opening procedure of the Xperia Z4.
  3. Sony Xperia Z5 Rear Camera Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z5 Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Carefully lift and remove the rear glass.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  4. Sony Xperia Z5 Rear Camera Replacement, Battery Disconnect: 步骤 4 中的图像 1,2 Sony Xperia Z5 Rear Camera Replacement, Battery Disconnect: 步骤 4 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery flex cable.
  5. Sony Xperia Z5 Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,2 Sony Xperia Z5 Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 2,2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  6. Sony Xperia Z5 Rear Camera Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z5 Rear Camera Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z5 Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Remove the rear camera with a pair of tweezers.
    • Compare your new replacement part to the original part — you may need to transfer a rubber gasket to your new part before installing.
结论
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
202,860 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,757篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 508
