简介
本指南将向您展示如何更换Sony Xperia Z5中的电池。
你所需要的
加热后盖软化粘合剂。
放置吸盘并插入金属开口工具,从上面打开一个间隙。
插入小拨片并将其滑动以去除下面的粘合剂。
取下后壳。
Does the adhesive in this step need to be replaced? Don't really want to lose the water proofing…
Usually the adhesive is slightly damaged during the opening procedure which might void the water resistance of the phone. So to re-seal the back cover it’s best to use fresh adhesive. If you don’t find a pre-cut adhesive tailored to the Z5 you can go with double-sided adhesive tape or an adhesive glue. If you find the remaining adhesive in good condition and trust it to do its job, the re-use it by heating it up a little bit and applying pressure to the re-attached back cover for a few hours.
松开电池连接器,然后拉下下面的胶带。
撬开电池。
Can you tell me the wire connection colour code of battery? because i brought the ones but its not working.
denkim2701 - 回复
25等其他人完成本指南。
由衷感谢以下译者:
100%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
worked a treat - simple straightforward - thanks!!
umm how do you put the cover back on?
Just push and then consolidate with heat, I used hair dryer.
can reuse the same cover, or need a new unit ?
