跳转到主内容
Sony Xperia Z3 Dual Main flex Replacement
你所需要的
  1. Sony Xperia Z3 Dual Main flex Replacement, Main flex: 步骤 1 中的图像 1,2 Sony Xperia Z3 Dual Main flex Replacement, Main flex: 步骤 1 中的图像 2,2
    • Heat to soften back cover sticker.
    • Place suction cup and pull open a gap.
  2. Sony Xperia Z3 Dual Main flex Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 2 中的图像 3,3
    • Insert into guitar pick, slide and cut the sticker. Finally, remove the back cover.
  3. Sony Xperia Z3 Dual Main flex Replacement: 步骤 3 中的图像 1,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 3 中的图像 2,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 3 中的图像 3,3
    • Remove the battery.
  4. Sony Xperia Z3 Dual Main flex Replacement: 步骤 4 中的图像 1,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 4 中的图像 2,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 4 中的图像 3,3
    • Twist off two screws here.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove vibrator securing bracket.
  5. Sony Xperia Z3 Dual Main flex Replacement: 步骤 5 中的图像 1,2 Sony Xperia Z3 Dual Main flex Replacement: 步骤 5 中的图像 2,2
    • Remove loudspeaker assembly cover and assembly itself.
  6. Sony Xperia Z3 Dual Main flex Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 6 中的图像 3,3
    • Pry up the MIC. It's a part of the main flex.
    • Release the connector with LCD screen flex and the connector with motherboard.
  7. Sony Xperia Z3 Dual Main flex Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 7 中的图像 3,3
    • Push the upper power button & volume button flex branch bracket as the direction marked, and then remove it easily.
    • Pry up the lower shutter button flex branch bracket carefully. It's different from the upper one, it's come with the flex together but the upper one not.
  8. Sony Xperia Z3 Dual Main flex Replacement: 步骤 8 中的图像 1,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 8 中的图像 2,3 Sony Xperia Z3 Dual Main flex Replacement: 步骤 8 中的图像 3,3
    • Get the flex from the sticker underneath carefully.
    • And then, take the power button & volume button flex branch out from the slot.
    • Finally, remove the whole main flex.
结论
16等其他人完成本指南。
Sophia
于03/25/14注册
43,861 声望
创作了62篇指南
4条评论
Hello
I changed my power, but I felt the power button action do you think the problem of what can be
Thanks
mehdi ghanbarian - 回复
Is it ok to remove the small copper stickers under the flex?
Miguel Damayo - 回复
اريد المنتج هذا
H ammody - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 9,914
