跳转到主内容
Sony Xperia Z3 Dual Back Cover Replacement
你所需要的
视频概述
  1. Sony Xperia Z3 Dual Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
  2. Sony Xperia Z3 Dual Back Cover Replacement: 步骤 2 中的图像 1,1
    • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
  3. Sony Xperia Z3 Dual Back Cover Replacement: 步骤 3 中的图像 1,1
    • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
  4. Sony Xperia Z3 Dual Back Cover Replacement: 步骤 4 中的图像 1,1
    • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
  5. Sony Xperia Z3 Dual Back Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the back cover easily. It comes with camera lens and NFC.
    • And you can place your new back cover, press the adhesive sticker and done the replacement.
结论
12等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
2条评论
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
Winstonmary Dimagnaong - 回复
Are you sure that the replacement parts mentioned above would work for the Z3 DUAL as well? I believe it has a slightly different size or shape compared to the regular Z3
Shevek - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 21,136
