跳转到主内容
Sony Xperia Z3 Compact Main Flex Replacement
你所需要的
  1. Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: 步骤 1 中的图像 1,3 Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: 步骤 1 中的图像 2,3 Sony Xperia Z3 Compact Main Flex Replacement, Main Flex: 步骤 1 中的图像 3,3
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Sony Xperia Z3 Compact Main Flex Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 2 中的图像 3,3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Sony Xperia Z3 Compact Main Flex Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Main Flex Replacement: 步骤 4 中的图像 1,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 4 中的图像 2,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 4 中的图像 3,3
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Main Flex Replacement: 步骤 5 中的图像 1,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 5 中的图像 2,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 5 中的图像 3,3
    • Release connectors and screw.
  6. Sony Xperia Z3 Compact Main Flex Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 6 中的图像 3,3
    • Remove motherboard.
    be very careful with the flex cable that is connected to the vibrator, it is very easy to break that when removing motherboard
    anonymous 8554 - 回复
    vibrator with orange silicon cover is fixed with sticker. you better pull it off with spudger before removing the motherboard
    jibou1356 - 回复
    yup, broke mine. Should've come here first. I'll leave it the way it is. I'm not replacing the entire main flex just for this.
    PETRISOR M - 回复
  7. Sony Xperia Z3 Compact Main Flex Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z3 Compact Main Flex Replacement: 步骤 7 中的图像 3,3
    • Remove main flex.
结论
5等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
6条评论
hi dear
my mobile (sony xperia z3 mini ) it problem in screen, i changed screen but still not work always black how can i do to fixed my mobile ???? plz help me
BR
Swren
swren1987 - 回复
Sony's TFT LCD IPS Fuse exploded on Logic Board. Just solder it out. Use a Good Solder + Microscope.
Compact Z3: https://youtu.be/B3GHVfFs2hU?t=263
Logic BoardCHF 23.04 | 32GB Original Motherboard Für Sony Xperia Z3 MINI D5803 D5833 100% Entsperrt Mainboard Android OS Logic board Mit Chips ersetzen++https://a.aliexpress.com/_BUGwJ5++
TFT LCD IPSCHF 17.92 | Original 4.6 ''Für Sony Xperia Z3 compact z3 mini D5803 D5833 LCD Display Touchscreen Digitizer Montage mit rahmen ohne F++https://a.aliexpress.com/_B0hkDt++
Normal Big Z3: ++https://youtu.be/ZUm7n0tCZVM?t=45++
5803 = EU + USA
5833 = Australia + Asia
++https://www.quora.com/What-is-the-differ...
Buddha Buddha -
I can not loosen a screw, what can I do?
Piero Sabino - 回复
Hey Fixit, I will repair my Wifi, but I can not find the component parts on the mainboard on the Z3c
Have a description where is the wifi component similar to these video because on the Z3Compact?
http://www.youtube.com/watch?v=dvq1zkiu4...
Sofie - 回复
is there label imei or meid in it ???
Ardians Faqih - 回复
Yes, there is a label in the phone with IMEI info. For some reason, it’s not show on the pictures, but you can see the label simply by opening the bottom port cover on the left side of the phone and pulling on it. The IMEI is the number written on the top right of the label.
axel -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 17,112
