简介
解决索尼Xperia Z3 Compact上显示屏破碎问题。 在这个视频之后,您可以自己修复破碎的Xperia Z3 Compact的屏幕。
[视频链接|https://www.youtube.com/watch?v=ibb22uof...]
请注意,本指南介绍如何更换LCD +触摸屏组件。 替代维修是取代LCD +触摸屏+中框,可以作为预装组合购买。
你所需要的
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
104等其他人完成本指南。
由衷感谢以下译者:
20%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
41指南评论
Be really careful placing the glue/sticker for the front cover to go back on, I had a small ruck underneath and it cracked my replacement screen, so annoyed! Other than that everything is pretty easy.
so true,
also to note is the earpiece speaker sits below the plane of the glass if you remove the existing adhesive on the earpiece. when pressing down the new glass in this area, it's soo easy to break your brand new replacement screen because of the depression. in my opinion, Xperia phones have an excessively fragile construction and very brittle, thin glass..
Andrew -
My screen was broken so unable to switch of phone so switched screen with power on.
When the screen was replaced everything seemed Ok but the digitizer/touch did not work so I thought I had zapped the screen.
I then disconnected - reconnected the battery and cold rebooted the phone and that got the digitizer working.
So I suggest that You disconnect the battery before connecting the new screen to ensure the power is off
Ingemar 1508027
are this devise water proof after it and what is the name of the Glue that u used for glue the new lcd
You magnificent responder!!! I totally panicked when everything worked except for the touch part of my screen, then I just detached and reattached the battery and now everything works perfectly. Thank you!
