跳转到主内容
Sony Xperia Z3 Compact Front Camera Replacement
你所需要的
  1. Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,3 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,3 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: 步骤 1 中的图像 3,3
    • Carefully use a heat gun or hairdryer to melt the adhesive holding the rear case to the phone.
    • Use a suction cup to lift the rear case slightly, enough to slide an opening pick around the edge and loosen the adhesive.
    • Remove back cover.
  2. Sony Xperia Z3 Compact Front Camera Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 2 中的图像 3,3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove the midframe.
    • Be aware that there are small tabs holding the midframe into the frame of the phone. These are located at the top and along the sides. You may need pry gently pry the midframe out with the flat end of a spudger.
  3. Sony Xperia Z3 Compact Front Camera Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Front Camera Replacement: 步骤 4 中的图像 1,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 4 中的图像 2,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 4 中的图像 3,3
    • Remove bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Front Camera Replacement: 步骤 5 中的图像 1,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 5 中的图像 2,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 5 中的图像 3,3
    • Release connectors and screw.
  6. Sony Xperia Z3 Compact Front Camera Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 6 中的图像 3,3
    • Remove motherboard.
  7. Sony Xperia Z3 Compact Front Camera Replacement: 步骤 7 中的图像 1,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 7 中的图像 2,3 Sony Xperia Z3 Compact Front Camera Replacement: 步骤 7 中的图像 3,3
    • Remove front camera.
结论
3等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 6,954
