跳转到主内容
Sony Xperia Z3 Back Cover Replacement
你所需要的
  1. Sony Xperia Z3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Sony Xperia Z3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Sony Xperia Z3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
    • If you use an iOpener, follow these instructions for use.
    • Lift up the back cover with a suction handle and put an opening pick in the gap.
    • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
    • Don't put the pick in too deep under the back cover to not damage any parts inside the phone.
  2. Sony Xperia Z3 Back Cover Replacement: 步骤 2 中的图像 1,2 Sony Xperia Z3 Back Cover Replacement: 步骤 2 中的图像 2,2
    • There are two adhesive strips in the center of the phone connecting the rear case to the battery, you'll need to remove them to open the phone.
    • When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
    • Use tweezers to pull the two black adhesive strips out of the phone but don't pull just yet.
  3. Sony Xperia Z3 Back Cover Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z3 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
    • If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again.
  4. Sony Xperia Z3 Back Cover Replacement: 步骤 4 中的图像 1,2 Sony Xperia Z3 Back Cover Replacement: 步骤 4 中的图像 2,2
    • After pulling out the adhesive tabs, you can lift the back cover and remove it.
结论
6等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
114,261 声望
创作了188篇指南
团队
iFixit iFixit 的会员
Community
142 名成员
创作了16,232篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 36
总计 5,973
