简介
Use this guide to replace the back cover of your Sony Z3.
Heat the back cover of your Xperia Z3 to loosen the adhesive underneath. Lift up the back cover with a suction handle and put an opening pick in the gap. Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
  • Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
  • Lift up the back cover with a suction handle and put an opening pick in the gap.
  • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
  • Don't put the pick in too deep under the back cover to not damage any parts inside the phone.
How hot (how many C) should the iOpener be? I think it would be safer / more accurate to heat the iOpener in an oven with accurate temperature control.
Magnus Myklebost - 回复
Careful here. The back cover cracked in two places. Once when I exerted pressure with the suction handle, and in the corner when moving the pick around the edges- even though I was very gentle. The battery was adhered firmly to the back cover.
Joseph Doyle - 回复
After the adhesive around the egdes is loosened, pull up the back cover with your suction handle. Use a tweezer to pull out two black straps that are attached to two pieces of adhesive right on the battery.
  • After the adhesive around the egdes is loosened, pull up the back cover with your suction handle.
  • Use a tweezer to pull out two black straps that are attached to two pieces of adhesive right on the battery.
添加评论
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Gently pull out both of the black straps with the adhesive tabs. Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs right in between. In this case use a plastic card to pry off the back cover carefully, use heat if necessary !
  • Gently pull out both of the black straps with the adhesive tabs.
  • Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs right in between. In this case use a plastic card to pry off the back cover carefully, use heat if necessary !
添加评论
After pulling out the adhesive tabs, you can lift the back cover  and remove it. After pulling out the adhesive tabs, you can lift the back cover  and remove it.
  • After pulling out the adhesive tabs, you can lift the back cover and remove it.
添加评论
结论
3等其他人完成本指南。
Tobias Isakeit
于2014年03月31日注册
22,750 信誉积分
创作了189篇指南
团队
iFixit iFixit 的会员
Community
117 名成员
创作了5,581篇指南
添加评论
浏览统计数据:
过去的24小时: 5
过去的7天: 32
过去的30天: 119
总计 1,865
