跳转到主内容
Sony Xperia Z2 Wi-Fi Antenna Replacement
你所需要的
视频概述
  1. Sony Xperia Z2 Wi-Fi Antenna Replacement, Rear / Battery Cover: 步骤 1 中的图像 1,3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Rear / Battery Cover: 步骤 1 中的图像 2,3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Rear / Battery Cover: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Wi-Fi Antenna Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z2 Wi-Fi Antenna Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z2 Wi-Fi Antenna Replacement: 步骤 2 中的图像 3,3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Wi-Fi Antenna Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z2 Wi-Fi Antenna Replacement: 步骤 3 中的图像 2,2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Wi-Fi Antenna Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Battery: 步骤 4 中的图像 3,3
  5. Sony Xperia Z2 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 5 中的图像 1,3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 5 中的图像 2,3 Sony Xperia Z2 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 5 中的图像 3,3
    • Unscrew the screw and remove the Wi-Fi Antenna.
结论
11等其他人完成本指南。
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,539篇指南
3条评论
Continu your learning
jafar khalili - 回复
hi got my Xperia z replace the broken screen and I was told that the antenna is broke, wait over week to get fixed and still the antenna is so weak I couldn't load my Face Book
kalipatamar - 回复
This guide seems to have been written just to promote the author’s own website. The advice is very poor, misleading and unhelpful.
(1) Removing the back panel will destroy it. All intending any repairs should have a replacement panel available before beginning.
(2) Replacing battery is as described.
(3) Author does not identify the wifi antenna correctly, nor supply advice on replacing it. Actually the wifi antenna is located at the lower right corner of the Xperia Z2 not upper left as shown. A connector wire runs along the edge in a groove and leads up to a connection on the motherboard. To replace wifi antenna unclip the connector, unscrew the mini circuit board, then reverse the steps with new board/connector.
MooMooUK - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 49
总计 21,921
