跳转到主内容
Sony Xperia Z2 Main Camera Replacement
你所需要的
视频概述
  1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: 步骤 1 中的图像 1,3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: 步骤 1 中的图像 2,3 Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Main Camera Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z2 Main Camera Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z2 Main Camera Replacement: 步骤 2 中的图像 3,3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Main Camera Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z2 Main Camera Replacement: 步骤 3 中的图像 2,2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Main Camera Replacement, Main Camera: 步骤 4 中的图像 1,2 Sony Xperia Z2 Main Camera Replacement, Main Camera: 步骤 4 中的图像 2,2
结论
9等其他人完成本指南。
ZFix
于12/09/13注册
191,882 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,516篇指南
7条评论
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - 回复
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - 回复
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 9,135
