跳转到主内容
Sony Xperia Z2 Loudspeaker Replacement
你所需要的
视频概述
  1. Sony Xperia Z2 Loudspeaker Replacement, Rear / Battery Cover: 步骤 1 中的图像 1,3 Sony Xperia Z2 Loudspeaker Replacement, Rear / Battery Cover: 步骤 1 中的图像 2,3 Sony Xperia Z2 Loudspeaker Replacement, Rear / Battery Cover: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Loudspeaker Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z2 Loudspeaker Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z2 Loudspeaker Replacement: 步骤 2 中的图像 3,3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Loudspeaker Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z2 Loudspeaker Replacement: 步骤 3 中的图像 2,2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Loudspeaker Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia Z2 Loudspeaker Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia Z2 Loudspeaker Replacement, Battery: 步骤 4 中的图像 3,3
  5. Sony Xperia Z2 Loudspeaker Replacement, Loudspeaker: 步骤 5 中的图像 1,3 Sony Xperia Z2 Loudspeaker Replacement, Loudspeaker: 步骤 5 中的图像 2,3 Sony Xperia Z2 Loudspeaker Replacement, Loudspeaker: 步骤 5 中的图像 3,3
    • Remove the Loudspeaker metal bracket.
  6. Sony Xperia Z2 Loudspeaker Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z2 Loudspeaker Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z2 Loudspeaker Replacement: 步骤 6 中的图像 3,3
    • Part of the Volume/PowerON/Mic flex cable is affixed onto the Loudspeaker/Vibro motor module.
    • Under the Flex cable is the Loudspeaker.
    • You can change only the Loudspeaker or or the Loudspeaker & Holder module.
    • Loudspeaker & Holder module Part No: 1282-2013
    • Please SUBSCRIBE to my channel ツ
结论
4等其他人完成本指南。
ZFix
于12/09/13注册
191,341 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,540篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 14
总计 9,620
