跳转到主内容
Sony Xperia Z2 Earpiece Replacement
你所需要的
视频概述
  1. Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: 步骤 1 中的图像 1,3 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: 步骤 1 中的图像 2,3 Sony Xperia Z2 Earpiece Replacement, Rear / Battery Cover: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Earpiece Replacement: 步骤 2 中的图像 1,3 Sony Xperia Z2 Earpiece Replacement: 步骤 2 中的图像 2,3 Sony Xperia Z2 Earpiece Replacement: 步骤 2 中的图像 3,3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Earpiece Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z2 Earpiece Replacement: 步骤 3 中的图像 2,2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Earpiece Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia Z2 Earpiece Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia Z2 Earpiece Replacement, Battery: 步骤 4 中的图像 3,3
  5. Sony Xperia Z2 Earpiece Replacement, Logic Board: 步骤 5 中的图像 1,2 Sony Xperia Z2 Earpiece Replacement, Logic Board: 步骤 5 中的图像 2,2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  6. Sony Xperia Z2 Earpiece Replacement: 步骤 6 中的图像 1,3 Sony Xperia Z2 Earpiece Replacement: 步骤 6 中的图像 2,3 Sony Xperia Z2 Earpiece Replacement: 步骤 6 中的图像 3,3
  7. Sony Xperia Z2 Earpiece Replacement, Earpiece: 步骤 7 中的图像 1,1
结论
7等其他人完成本指南。
ZFix
于12/09/13注册
191,368 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,465篇指南
3条评论
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
Claes - 回复
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
Mahtab - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 7,620
