跳转到主内容
Sony Xperia Z1 Rear Camera Replacement
你所需要的
  1. Sony Xperia Z1 Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,1
    • With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
  2. Sony Xperia Z1 Rear Camera Replacement: 步骤 2 中的图像 1,2 Sony Xperia Z1 Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Apply a suction cup tool to the center of the back panel and gently pull the panel off the back of the phone.
    • If you are experiencing difficulty, use a plastic opening pick to slide into the crack in between the panel and the rest of the phone body to pry off the back.
  3. Sony Xperia Z1 Rear Camera Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z1 Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, carefully pry off the flex connector beside the camera housing.
  4. Sony Xperia Z1 Rear Camera Replacement: 步骤 4 中的图像 1,2 Sony Xperia Z1 Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Use the tweezers to pull the camera out of the top left corner of the phone.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 16
总计 344
