简介
This guide will show you how you replace the headphone jack.
你所需要的
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
To remove the headphone jack, cut the sticker between the headphone jack and the midframe with sharp tweasers.
即将完成!
结论
