跳转到主内容
Sony Xperia Z1 Compact Battery Replacement
你所需要的
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: 步骤 2 中的图像 1,1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: 步骤 3 中的图像 1,2 Sony Xperia Z1 Compact Battery Replacement: 步骤 3 中的图像 2,2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: 步骤 4 中的图像 1,2 Sony Xperia Z1 Compact Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: 步骤 5 中的图像 1,2 Sony Xperia Z1 Compact Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Battery Replacement: 步骤 6 中的图像 1,1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the battery from the device
结论
12等其他人完成本指南。
kinan badr
于09/21/17注册
386 声望
撰写一个指南
团队
3条评论
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - 回复
What is the Ariel stuck on the battery ?
Tony - 回复
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 11,466
