简介
If you're trying to replace any of your Sony Xperia's internal components removing the battery is the first step. This guide will show you how to open and remove the battery from your phone.
你所需要的
Turn hair dryer to medium heat.
Slowly move the hair dryer along the seams on the back of the phone. Keep the dryer a few inches away from the case.
Circulate the dryer for a full minute to soften the adhesive binding the phone together.
Slide the spudger firmly along the right side of the battery, loosening the adhesive between the casing and battery.
Insert the spudger in the bottom-center to further loosen the adhesive. Carefully separate the battery from the phone by sliding the spudger vertically underneath the battery and prying up. This may take some time and work as the adhesive is very strong.
75等其他人完成本指南。
32条评论
Does battery replacement ruin the waterproof quality?
get reeplacing adheessment from part store.
Aft er replacing 2 (so called) waterproof phones due to water damage; I kept my Xperia phone away from water. Sony's claim the phone is weatherproof is a joke.
I found that a heavy plastic guitar pick (1.0mm or thicker) worked well as a replacement for the plastic opening tools
Me too... I agree.
remjok -
