跳转到主内容
加入维修社区 - 创建账户
Sony Xperia XZ2 Front Camera Replacement
你所需要的
  1. Sony Xperia XZ2 Front Camera Replacement, LCD Screen: 步骤 1 中的图像 1,3 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: 步骤 1 中的图像 2,3 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 Front Camera Replacement: 步骤 2 中的图像 1,3 Sony Xperia XZ2 Front Camera Replacement: 步骤 2 中的图像 2,3 Sony Xperia XZ2 Front Camera Replacement: 步骤 2 中的图像 3,3
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 Front Camera Replacement: 步骤 3 中的图像 1,2 Sony Xperia XZ2 Front Camera Replacement: 步骤 3 中的图像 2,2
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 Front Camera Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 Front Camera Replacement: 步骤 5 中的图像 1,1
    • Gently remove the connector by using a spudger to pop it off.
  6. Sony Xperia XZ2 Front Camera Replacement, Front Camera: 步骤 6 中的图像 1,1
    • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
    • Remove the one 3 mm Phillips #00 screws.
    • Remove the two 1mm Phillips #00 screws.
    • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
  7. Sony Xperia XZ2 Front Camera Replacement: 步骤 7 中的图像 1,1
    • Lift the metal screen shield out of the phone.
  8. Sony Xperia XZ2 Front Camera Replacement: 步骤 8 中的图像 1,3 Sony Xperia XZ2 Front Camera Replacement: 步骤 8 中的图像 2,3 Sony Xperia XZ2 Front Camera Replacement: 步骤 8 中的图像 3,3
    • Use the spudger to pop off the plastic protector.
  9. Sony Xperia XZ2 Front Camera Replacement: 步骤 9 中的图像 1,1
    • Gently pry up the battery flex connector using the spudger.
结论
Chloe
于01/24/19注册
229 声望
撰写一个指南
团队
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019 的会员
CPSU-WHITE-W19S19G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 1,321
