跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
You will learn how to remove the motherboard from the Sony Xperia XZ Premium. This process includes unscrewing nine screws and removing the frame pieces. It is important to keep your work-space organized because there will be several pieces of the phone removed.
  1. Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Take hold of the back panel with your fingers and remove.
    • Take hold of the back panel with your fingers and remove.
  4. Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
    • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
  5. Remove nine 3.9mm Phillips #000 screws. Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • Remove nine 3.9mm Phillips #000 screws.
    • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
    • When unscrewing, remember "Left Loosey, Righty Tighty!"
  6. Place the spudger under the top left corner frame piece and lift to loosen.
    • Place the spudger under the top left corner frame piece and lift to loosen.
  7. Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
    • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
  8. Place the spudger under the bottom left frame piece and lift to loosen it.
    • Place the spudger under the bottom left frame piece and lift to loosen it.
  9. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  10. Grab hold of bottom left frame piece with your fingers  and lift gently.
    • Grab hold of bottom left frame piece with your fingers and lift gently.
    • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
  11. Place the spudger under the top right frame piece and lift to loosen it.
    • Place the spudger under the top right frame piece and lift to loosen it.
  12. Grab hold of the top right frame piece  with your fingers and lift.
    • Grab hold of the top right frame piece with your fingers and lift.
  13. Insert your nail under the top left connector and push to disconnect it.
    • Insert your nail under the top left connector and push to disconnect it.
  14. Grab hold of the metal part of the connector with your fingers and lift.
    • Grab hold of the metal part of the connector with your fingers and lift.
  15. Insert your nail under the metal part of the bottom left connector.
    • Insert your nail under the metal part of the bottom left connector.
  16. Push the bottom left connector with your finger to disconnect it.
    • Push the bottom left connector with your finger to disconnect it.
  17. Insert your nail under the center topmost connector and push to loosen it.
    • Insert your nail under the center topmost connector and push to loosen it.
  18. Grab hold of the top connector with your fingers and lift to disconnect it.
    • Grab hold of the top connector with your fingers and lift to disconnect it.
  19. Insert your nail under the metal tab of the connector above the battery and push to loosen it.
    • Insert your nail under the metal tab of the connector above the battery and push to loosen it.
  20. Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
    • Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
  21. Insert spudger in the gap above the battery and lift to loosen the motherboard.
    • Insert spudger in the gap above the battery and lift to loosen the motherboard.
    • Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
  22. Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
    • Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
  23. Grab hold of the motherboard with your fingers and lift it out of the phone gently.
    • Grab hold of the motherboard with your fingers and lift it out of the phone gently.
结论
5等其他人完成本指南。
Gelene Amog
于2018年04月18日注册
967 信誉积分
创作了5篇指南
团队
Cal Poly, Team S18-G2, Livingston Spring 2018 Cal Poly, Team S18-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G2
5 名成员
创作了12篇指南
Where do you buy a motherboard for the xz premium? thank you
Jonathan Storm - 回复
where can you buy a motherboard for the xz premium G8142?
dukeduane - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 19
过去的30天: 113
总计 3,110
