跳转到主内容
Sony Xperia XA2 Ultra Rear Cover Replacement
你所需要的
  1. Sony Xperia XA2 Ultra Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 1,2 Sony Xperia XA2 Ultra Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 2,2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 2 中的图像 1,1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 3 中的图像 1,2 Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 3 中的图像 2,2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 4 中的图像 1,2 Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 4 中的图像 2,2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 5 中的图像 1,2 Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 5 中的图像 2,2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Rear Cover Replacement: 步骤 6 中的图像 1,1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
结论
Alyssa Bayles
于09/27/22注册
819 声望
创作了8篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 175
