跳转到主内容
Sony Xperia XA1 Ultra Battery Replacement
你所需要的
  1. Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: 步骤 1 中的图像 1,2 Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: 步骤 1 中的图像 2,2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Battery Replacement: 步骤 2 中的图像 1,1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Battery Replacement: 步骤 3 中的图像 1,1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Battery Replacement: 步骤 5 中的图像 1,1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Battery Replacement: 步骤 6 中的图像 1,1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Battery Replacement, Battery: 步骤 7 中的图像 1,3 Sony Xperia XA1 Ultra Battery Replacement, Battery: 步骤 7 中的图像 2,3 Sony Xperia XA1 Ultra Battery Replacement, Battery: 步骤 7 中的图像 3,3
    • Peel off the two pieces of black tape covering the battery with your hands.
  8. Sony Xperia XA1 Ultra Battery Replacement: 步骤 8 中的图像 1,2 Sony Xperia XA1 Ultra Battery Replacement: 步骤 8 中的图像 2,2
    • Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
  9. Sony Xperia XA1 Ultra Battery Replacement: 步骤 9 中的图像 1,3 Sony Xperia XA1 Ultra Battery Replacement: 步骤 9 中的图像 2,3 Sony Xperia XA1 Ultra Battery Replacement: 步骤 9 中的图像 3,3
    • Wedge the iFixit Opening Tool underneath the battery.
    • Remove the battery by pulling up on the iFixit Opening Tool.
结论
12等其他人完成本指南。
Jacob Jung
于04/18/18注册
1,429 声望
创作了9篇指南
团队
Cal Poly, Team S16-G3, Livingston Spring 2018 Cal Poly, Team S16-G3, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G3
4 名成员
创作了9篇指南
3条评论
magnificent…i successfully change a new battery for xperia xa1 ultra…its not the time yet for this xperia to retire from service to me…thank you very much
Wahyudi Hussaini - 回复
Wher did you get the batterry from? And is it good as the original?
very Green -
Where can I get the original battery
very Green - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 36
总计 10,188
