跳转到主内容
Sony Xperia XA Ultra Rear Facing Camera Replacement
你所需要的
  1. Sony Xperia XA Ultra Rear Facing Camera Replacement, Motherboard: 步骤 1 中的图像 1,2 Sony Xperia XA Ultra Rear Facing Camera Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
  2. Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Remove all 9 black 4mm T5 screws.
    • Remove all 8 silver 3mm T3 screws.
    • Make sure to carefully place each screw in a secure location to avoid losing any.
  3. Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 3 中的图像 1,3 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 3 中的图像 2,3 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 3 中的图像 3,3
    • Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
    • Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
    • Be careful when prying near the top of the device. The metal casing can be easily bent.
  4. Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the side bezels from each side, and remove the sim card cover.
  5. Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 5 中的图像 1,2 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, gently pry off the black charge port plate, located near the bottom of the phone.
    • Remove the sim card from sim card slot using fingernail or small plastic spudger.
  6. Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 6 中的图像 1,3 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 6 中的图像 2,3 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Disconnect all four of the shown electrical connectors by gently prying up with the plastic opening tool.
  7. Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 7 中的图像 1,2 Sony Xperia XA Ultra Rear Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Working from bottom to top, gently pry the motherboard off of the phone .
    • The camera is connected to the motherboard. Be extremely careful when removing it to avoid damage.
  8. Sony Xperia XA Ultra Rear Facing Camera Replacement, Rear Facing Camera: 步骤 8 中的图像 1,1
    • Using a plastic spudger, disconnect the camera from the motherboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 416
