简介
This guide is for removing the Battery of the Xperia XA Ultra. To complete this repair, you will need a T3 and T5 Torx screwdriver as well as a plastic spudger to pry open certain parts of the phone. A hairdryer or any other device that can supply heat is recommended to loosen the glue holding the components together, although it is possible to complete the replacement without.
你所需要的
Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
Using a plastic spudger, carefully pry off the battery you intend to replace.
Place new battery in the battery space.
