当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Apply heat on the back surface of the phone.
Continue to heat the device as needed throughout the replacement process.
The device can get very hot, so be careful when handling it.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Pull the back of the phone case away from the device.
You will hear popping sounds of glue being ripped from the phone.
You will hear the sound of the back unlatching from the device.
You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
RAF antenna may be attached to the back cover upon removal.
Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
Peel back the tab past the connector.
Tab is stuck with adhesive.
With the spudger, pry the headphone jack located in the top right corner of the phone.
The new headphone jack snaps into place in the right corner between the retaining clips.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
