本指南有最近更改,您可查看未经巡查的最新版本。
简介
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device. The headphone jack is held in by plastic retaining clips and may pop off when removed.
你所需要的
With the spudger, pry the headphone jack located in the top right corner of the phone.
即将完成!
结论
另外一个人完成了本指南。
