跳转到主内容
Sony Xperia XA Battery Replacement
你所需要的
  1. Sony Xperia XA Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: 步骤 2 中的图像 1,1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: 步骤 3 中的图像 1,3 Sony Xperia XA Battery Replacement: 步骤 3 中的图像 2,3 Sony Xperia XA Battery Replacement: 步骤 3 中的图像 3,3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: 步骤 4 中的图像 1,3 Sony Xperia XA Battery Replacement: 步骤 4 中的图像 2,3 Sony Xperia XA Battery Replacement: 步骤 4 中的图像 3,3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: 步骤 5 中的图像 1,1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Battery Replacement: 步骤 6 中的图像 1,1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Battery Replacement, Battery: 步骤 7 中的图像 1,3 Sony Xperia XA Battery Replacement, Battery: 步骤 7 中的图像 2,3 Sony Xperia XA Battery Replacement, Battery: 步骤 7 中的图像 3,3
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: 步骤 8 中的图像 1,2 Sony Xperia XA Battery Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: 步骤 9 中的图像 1,1
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: 步骤 10 中的图像 1,1
    • Lift the battery out with your hands.
结论
11等其他人完成本指南。
Cassidy Davis
于04/18/18注册
621 声望
撰写一个指南
团队
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G2
4 名成员
创作了8篇指南
一条评论
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 5,247
