跳转到主内容
Sony Xperia U Headphone Jack Replacement
你所需要的
  1. Sony Xperia U Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Headphone Jack Replacement, Headphone Jack: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Headphone Jack Replacement: 步骤 5 中的图像 1,1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
结论
2等其他人完成本指南。
Bader
于10/07/14注册
545 声望
创作了4篇指南
团队
USF Tampa, Team 7-2, Leahy Fall 2014 USF Tampa, Team 7-2, Leahy Fall 2014 的会员
USFT-LEAHY-F14S7G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,094
