跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Tablet Z Battery Replacement
你所需要的
  1. Sony Xperia Tablet Z Battery Replacement, Battery: 步骤 1 中的图像 1,2 Sony Xperia Tablet Z Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the plastic removal tool in the corner of the object.
    • Slide the plastic removal tool along the edges.
  2. Sony Xperia Tablet Z Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the cover.
    • Disconnect the battery to avoid electric shock by pulling up on the white plastic.
  3. Sony Xperia Tablet Z Battery Replacement: 步骤 3 中的图像 1,3 Sony Xperia Tablet Z Battery Replacement: 步骤 3 中的图像 2,3 Sony Xperia Tablet Z Battery Replacement: 步骤 3 中的图像 3,3
    • In the top right corner of the device remove the piece of tape connecting the front camera to the motherboard.
    • Then disconnect the camera from the motherboard.
    • Lift and remove the front camera to expose hidden screw to replace battery.
  4. Sony Xperia Tablet Z Battery Replacement: 步骤 4 中的图像 1,3 Sony Xperia Tablet Z Battery Replacement: 步骤 4 中的图像 2,3 Sony Xperia Tablet Z Battery Replacement: 步骤 4 中的图像 3,3
    • Remove all screws connecting the battery to the tablet. Location of screws shown with red circles.
    • Then lift the left side first then detach the connection in the lower right corner. Connection shown with orange box.
    • Completely remove the battery.
结论
26等其他人完成本指南。
Martin Luna
于09/24/14注册
1,873 声望
创作了5篇指南
团队
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 的会员
USFT-REMMELL-F14S15G6
3 名成员
创作了7篇指南
14指南评论
Helps me with info I need for a screen replacement. I'll post pics when I complete it. need a new screen first, hard to find for that model.
evildrifty - 回复
hi,
thanks for this tutorial. do you know where I can buy the tablet battery ? thanks for your help.
safae - 回复
Same question. Where would be the best place to purchase a battery? All I've found seems sketchy and I dont want to have a time bomb on hand.
Gui L - 回复
any one actially got any andswers about were to actually get this replacement battery.. WHY OH WHY do the tuitorial without mentiong were to find the fleeping replacement?????
AvoidSonyAllTogether - 回复
Hello friends, for Sony Xperia Tablet Z 4 same way ?
thank you for support
Andi - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 79
总计 46,969
