跳转到主内容
Sony Xperia TL Headphone Jack Replacement
你所需要的
  1. Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: 步骤 1 中的图像 1,3 Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: 步骤 1 中的图像 2,3 Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: 步骤 2 中的图像 1,2 Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: 步骤 3 中的图像 1,3 Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: 步骤 3 中的图像 2,3 Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: 步骤 3 中的图像 3,3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Headphone Jack Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia TL Headphone Jack Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia TL Headphone Jack Replacement, Battery: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: 步骤 5 中的图像 1,2 Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Headphone Jack Replacement, Motherboard: 步骤 6 中的图像 1,3 Sony Xperia TL Headphone Jack Replacement, Motherboard: 步骤 6 中的图像 2,3 Sony Xperia TL Headphone Jack Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Headphone Jack Replacement, Headphone Jack: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to detach the headphone jack from the motherboard.
    • Remove the motherboard and slide the headphone jack out of its slot.
结论
另外一个人完成了本指南。
Nathan Laneau
于09/22/14注册
435 声望
创作了2篇指南
团队
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 的会员
USFT-BROWN-F14S4G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 192
