跳转到主内容
Sony Xperia TL Ear Speaker Replacement
你所需要的
  1. Sony Xperia TL Ear Speaker Replacement, Remove Top Plastic Section: 步骤 1 中的图像 1,3 Sony Xperia TL Ear Speaker Replacement, Remove Top Plastic Section: 步骤 1 中的图像 2,3 Sony Xperia TL Ear Speaker Replacement, Remove Top Plastic Section: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Ear Speaker Replacement, Remove Bottom Plastic Section: 步骤 2 中的图像 1,2 Sony Xperia TL Ear Speaker Replacement, Remove Bottom Plastic Section: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Ear Speaker Replacement, Unscrewing the Back Off: 步骤 3 中的图像 1,3 Sony Xperia TL Ear Speaker Replacement, Unscrewing the Back Off: 步骤 3 中的图像 2,3 Sony Xperia TL Ear Speaker Replacement, Unscrewing the Back Off: 步骤 3 中的图像 3,3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Ear Speaker Replacement, Battery: 步骤 4 中的图像 1,3 Sony Xperia TL Ear Speaker Replacement, Battery: 步骤 4 中的图像 2,3 Sony Xperia TL Ear Speaker Replacement, Battery: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Ear Speaker Replacement, Sony Xperia TL Auxiliary Cord Replacement: 步骤 5 中的图像 1,2 Sony Xperia TL Ear Speaker Replacement, Sony Xperia TL Auxiliary Cord Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Ear Speaker Replacement, Motherboard: 步骤 6 中的图像 1,3 Sony Xperia TL Ear Speaker Replacement, Motherboard: 步骤 6 中的图像 2,3 Sony Xperia TL Ear Speaker Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Ear Speaker Replacement, Ear Speaker: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
结论
另外一个人完成了本指南。
Adam Giniger
于09/22/14注册
1,303 声望
创作了8篇指南
团队
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 的会员
USFT-BROWN-F14S4G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 254
