跳转到主内容
简介
I will teach the guide reader how to access this piece and to replace it, it must be purchased.
  1. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
    • Use the plastic opening tool to pry the top plastic section off.
  2. Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module.
    • Use the plastic opening tool to remove the loud speaker module.
  5. Use the plastic opening tool to detach the ribbon running across the battery. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard. Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  6. Unhook the 2 connections between the harness and phone shell. Using the plastic opening tool, pry the harness up and remove it. There is an adhesive on the bottom half of the battery harness.
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. The final step is taking the entire harness off of the phone.
    • The final step is taking the entire harness off of the phone.
  8. Use the Phillips #00 to remove the 3 5mm screws. Lift the plastic cover off. Use the plastic opening tool to pry the motherboard out of the phone shell.
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  9. Use the plastic opening tool to detach the ear piece speaker.
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
  10. Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
结论
另外一个人完成了本指南。
Adam Giniger
于2014年09月22日注册
1,303 信誉积分
创作了8篇指南
团队
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 的会员
USFT-BROWN-F14S4G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 486
