跳转到主内容
Sony Xperia TL Battery Harness Replacement
你所需要的
  1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: 步骤 1 中的图像 1,3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: 步骤 1 中的图像 2,3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: 步骤 2 中的图像 1,2 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: 步骤 3 中的图像 1,3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: 步骤 3 中的图像 2,3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: 步骤 3 中的图像 3,3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Harness Replacement, Loud Speaker: 步骤 4 中的图像 1,3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: 步骤 4 中的图像 2,3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: 步骤 5 中的图像 1,2 Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Battery Harness Replacement, Battery Harness: 步骤 6 中的图像 1,3 Sony Xperia TL Battery Harness Replacement, Battery Harness: 步骤 6 中的图像 2,3 Sony Xperia TL Battery Harness Replacement, Battery Harness: 步骤 6 中的图像 3,3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Battery Harness Replacement: 步骤 7 中的图像 1,1
    • The final step is taking the entire harness off of the phone.
结论
另外一个人完成了本指南。
Adam Giniger
于09/22/14注册
1,303 声望
创作了8篇指南
团队
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 的会员
USFT-BROWN-F14S4G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 287
