跳转到主内容
Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement
你所需要的
  1. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing the internal cover: 步骤 3 中的图像 1,1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing Chip: 步骤 5 中的图像 1,1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Remove back facing camera: 步骤 7 中的图像 1,1
    • Then using the tweezer, carefully remove the back facing camera component.
结论
5等其他人完成本指南。
团队
USF Tampa, Team 13-3, Staggers Fall 2014 USF Tampa, Team 13-3, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G3
3 名成员
创作了7篇指南
2条评论
Hlo hi sir Sony back cam of Sony Xperia t2 ultra
sai kiran - 回复
Hi, Sir T2 Ultra dual Camera shows error - Unfortunately, Camera has stopped working. pls help . Thank yo
Alan Mathew - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 4,128
