跳转到主内容
Sony Xperia T2 Ultra Dual Audio Jack Replacement
你所需要的
  1. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Audio Jack Replacement: 步骤 2 中的图像 1,1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Removing the internal cover: 步骤 3 中的图像 1,1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Audio Jack Replacement: 步骤 4 中的图像 1,2 Sony Xperia T2 Ultra Dual Audio Jack Replacement: 步骤 4 中的图像 2,2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Removing chip: 步骤 5 中的图像 1,1
    • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
  6. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Remove audio jack: 步骤 6 中的图像 1,1
    • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 13-3, Staggers Fall 2014 USF Tampa, Team 13-3, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G3
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,051
