跳转到主内容
Sony Xperia Sola Speaker Replacement
你所需要的
  1. Sony Xperia Sola Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Lay the phone as shown and put the camera facing up.
  2. Sony Xperia Sola Speaker Replacement: 步骤 2 中的图像 1,2 Sony Xperia Sola Speaker Replacement: 步骤 2 中的图像 2,2
    • Push the back cover as shown, then lift the cover off.
  3. Sony Xperia Sola Speaker Replacement: 步骤 3 中的图像 1,3 Sony Xperia Sola Speaker Replacement: 步骤 3 中的图像 2,3 Sony Xperia Sola Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the five screws as shown on the phone by using 26 Bit Kit.
    • Use a T6 screwdriver bit to remove top two screws.
    • Use a J000 screwdriver bit to remove the bottom two screws.
    • Use a T3 screwdriver bit to remove the middle screw (close to camera).
  4. Sony Xperia Sola Speaker Replacement: 步骤 4 中的图像 1,2 Sony Xperia Sola Speaker Replacement: 步骤 4 中的图像 2,2
    • Use plastic opening tool to remove the bottom white cover as shown.
  5. Sony Xperia Sola Speaker Replacement: 步骤 5 中的图像 1,2 Sony Xperia Sola Speaker Replacement: 步骤 5 中的图像 2,2
    • There are two additional screws under the bottom white cover as shown.
    • Use T3 drivers to remove two additional screws as shown.
  6. Sony Xperia Sola Speaker Replacement: 步骤 6 中的图像 1,3 Sony Xperia Sola Speaker Replacement: 步骤 6 中的图像 2,3 Sony Xperia Sola Speaker Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using plastic opening tool, lift to remove the small black cover on the bottom left of phone as shown.
    • Then, using tweezers to lift the connector straight up to disconnect the battery's circuit as shown.
  7. Sony Xperia Sola Speaker Replacement: 步骤 7 中的图像 1,3 Sony Xperia Sola Speaker Replacement: 步骤 7 中的图像 2,3 Sony Xperia Sola Speaker Replacement: 步骤 7 中的图像 3,3
    • Turn the phone onto its side and insert a flat object and gently remove cover, using plastic opening tool as shown.
  8. Sony Xperia Sola Speaker Replacement: 步骤 8 中的图像 1,3 Sony Xperia Sola Speaker Replacement: 步骤 8 中的图像 2,3 Sony Xperia Sola Speaker Replacement: 步骤 8 中的图像 3,3
    • Flip over the black back cover and locate the speaker phone at the bottom, then use the tweezers to remove the speaker. It is glued to the back cover so a little force will be needed.
结论
3等其他人完成本指南。
Bo Wu
于02/15/17注册
292 声望
创作了2篇指南
团队
USF Tampa, Team S5-G3, Lacy Spring 2017 USF Tampa, Team S5-G3, Lacy Spring 2017 的会员
USFT-LACY-S17S5G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 348
