跳转到主内容
Sony Xperia Sola LCD Screen Replacement
你所需要的
  1. Sony Xperia Sola LCD Screen Replacement, Lay the phone as shown.: 步骤 1 中的图像 1,2 Sony Xperia Sola LCD Screen Replacement, Lay the phone as shown.: 步骤 1 中的图像 2,2
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  2. Sony Xperia Sola LCD Screen Replacement, Remove the screws.: 步骤 2 中的图像 1,3 Sony Xperia Sola LCD Screen Replacement, Remove the screws.: 步骤 2 中的图像 2,3 Sony Xperia Sola LCD Screen Replacement, Remove the screws.: 步骤 2 中的图像 3,3
    • Locate and remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
  3. Sony Xperia Sola LCD Screen Replacement, Remove bottom white cover.: 步骤 3 中的图像 1,2 Sony Xperia Sola LCD Screen Replacement, Remove bottom white cover.: 步骤 3 中的图像 2,2
    • Pry off the bottom white cover by using the opening tool as a lever.
  4. Sony Xperia Sola LCD Screen Replacement, Remove more screws.: 步骤 4 中的图像 1,2 Sony Xperia Sola LCD Screen Replacement, Remove more screws.: 步骤 4 中的图像 2,2
    • Locate and remove the 2 additional screws, using the Torx screwdriver, that are revealed. These are marked as shown.
  5. Sony Xperia Sola LCD Screen Replacement, Remove black cover.: 步骤 5 中的图像 1,2 Sony Xperia Sola LCD Screen Replacement, Remove black cover.: 步骤 5 中的图像 2,2
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  6. Sony Xperia Sola LCD Screen Replacement, Disconnect the battery's circuit.: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  7. Sony Xperia Sola LCD Screen Replacement, Remove the phone's inner back cover.: 步骤 7 中的图像 1,3 Sony Xperia Sola LCD Screen Replacement, Remove the phone's inner back cover.: 步骤 7 中的图像 2,3 Sony Xperia Sola LCD Screen Replacement, Remove the phone's inner back cover.: 步骤 7 中的图像 3,3
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  8. Sony Xperia Sola LCD Screen Replacement, Remove the additional power circuit.: 步骤 8 中的图像 1,1
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  9. Sony Xperia Sola LCD Screen Replacement, Repeat for the circuit on the top end of the battery.: 步骤 9 中的图像 1,2 Sony Xperia Sola LCD Screen Replacement, Repeat for the circuit on the top end of the battery.: 步骤 9 中的图像 2,2
    • Use the tweezers to lift up on the circuit located at the top left.
  10. Sony Xperia Sola LCD Screen Replacement, Remove the motherboard.: 步骤 10 中的图像 1,1
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  11. Sony Xperia Sola LCD Screen Replacement, Remove the LCD screen.: 步骤 11 中的图像 1,3 Sony Xperia Sola LCD Screen Replacement, Remove the LCD screen.: 步骤 11 中的图像 2,3 Sony Xperia Sola LCD Screen Replacement, Remove the LCD screen.: 步骤 11 中的图像 3,3
    • Use either the plastic opener or the spudger to slid in the side. It will go in between the LCD screen and the spot you pulled the board off of.
结论
5等其他人完成本指南。
Cary Drew
于09/25/14注册
866 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Brown Fall 2014 USF Tampa, Team 1-1, Brown Fall 2014 的会员
USFT-BROWN-F14S1G1
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,190
