跳转到主内容
Sony Xperia Sola Headphone Jack Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Sony Xperia Sola Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Lay phone face down with camera away from you as shown.
  2. Sony Xperia Sola Headphone Jack Replacement: 步骤 2 中的图像 1,2 Sony Xperia Sola Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Push the cover up as shown in first picture. Then lift to remove as shown in the second.
  3. Sony Xperia Sola Headphone Jack Replacement: 步骤 3 中的图像 1,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 3 中的图像 2,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 3 中的图像 3,3
    • The screws unfortunately require different heads on the screw driver so you will want to use the 26 Bit Kit. Make sure to keep them separated once removed by using the magnetic mat.
  4. Sony Xperia Sola Headphone Jack Replacement: 步骤 4 中的图像 1,2 Sony Xperia Sola Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Slide a spudger or plastic opener under the white cover (as shown) and push toward your body to pop the cover off the end.
  5. Sony Xperia Sola Headphone Jack Replacement: 步骤 5 中的图像 1,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 5 中的图像 2,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Again, using the 26 Bit Kit and the magnetic mat. These screws would be revealed by the removal of the white cover.
  6. Sony Xperia Sola Headphone Jack Replacement: 步骤 6 中的图像 1,2 Sony Xperia Sola Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Slide either the plastic opener or the spudger under the black cover that is outlined and remove.
  7. Sony Xperia Sola Headphone Jack Replacement: 步骤 7 中的图像 1,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 7 中的图像 2,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 7 中的图像 3,3
    • You can do this from any side. Slide a flat object, either the plastic opener or the spudger, from the side and lift. You may feel resistance on the sides where the buttons are located, but this is normal.
  8. Sony Xperia Sola Headphone Jack Replacement: 步骤 8 中的图像 1,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 8 中的图像 2,3 Sony Xperia Sola Headphone Jack Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • The jack will be the the back cover you just removed. Insert removal tool, tweezers, into the jack and lift up, the jack will pop out. Replace with your new jack.
结论
3等其他人完成本指南。
Cary Drew
于09/25/14注册
866 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Brown Fall 2014 USF Tampa, Team 1-1, Brown Fall 2014 的会员
USFT-BROWN-F14S1G1
4 名成员
创作了5篇指南
一条评论
Need to include screw measurements to the nearest mm.
Dan Brown - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 353
