跳转到主内容
Sony Xperia Sola Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Sony Xperia Sola Battery Replacement, Lay the phone as shown.: 步骤 1 中的图像 1,1
    • Place phone down with screen side down and camera side facing up as shown.
  2. Sony Xperia Sola Battery Replacement, Remove the back cover.: 步骤 2 中的图像 1,1
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  3. Sony Xperia Sola Battery Replacement, Remove the screws.: 步骤 3 中的图像 1,3 Sony Xperia Sola Battery Replacement, Remove the screws.: 步骤 3 中的图像 2,3 Sony Xperia Sola Battery Replacement, Remove the screws.: 步骤 3 中的图像 3,3
    • Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown.
  4. Sony Xperia Sola Battery Replacement, Remove bottom white cover.: 步骤 4 中的图像 1,2 Sony Xperia Sola Battery Replacement, Remove bottom white cover.: 步骤 4 中的图像 2,2
    • Pry off the bottom white cover by using the opening tool as a lever.
  5. Sony Xperia Sola Battery Replacement, Remove more screws.: 步骤 5 中的图像 1,2 Sony Xperia Sola Battery Replacement, Remove more screws.: 步骤 5 中的图像 2,2
    • Locate and remove the 2 additional screws, using the 26 Bit Kit, that are revealed. These are marked as shown.
  6. Sony Xperia Sola Battery Replacement, Remove black cover.: 步骤 6 中的图像 1,2 Sony Xperia Sola Battery Replacement, Remove black cover.: 步骤 6 中的图像 2,2
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  7. Sony Xperia Sola Battery Replacement, Disconnect the battery's circuit.: 步骤 7 中的图像 1,1
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  8. Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: 步骤 8 中的图像 1,3 Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: 步骤 8 中的图像 2,3 Sony Xperia Sola Battery Replacement, Remove the phone's inner back cover.: 步骤 8 中的图像 3,3
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  9. Sony Xperia Sola Battery Replacement, Remove the additional power circuit.: 步骤 9 中的图像 1,1
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  10. Sony Xperia Sola Battery Replacement, Repeat for the circuit on the top end of the battery.: 步骤 10 中的图像 1,2 Sony Xperia Sola Battery Replacement, Repeat for the circuit on the top end of the battery.: 步骤 10 中的图像 2,2
    • Use the tweezers to lift up on the circuit located at the top left.
  11. Sony Xperia Sola Battery Replacement, Remove the motherboard.: 步骤 11 中的图像 1,1
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  12. Sony Xperia Sola Battery Replacement, Remove and replace the battery.: 步骤 12 中的图像 1,3 Sony Xperia Sola Battery Replacement, Remove and replace the battery.: 步骤 12 中的图像 2,3 Sony Xperia Sola Battery Replacement, Remove and replace the battery.: 步骤 12 中的图像 3,3
    • To remove battery, slide a flat object under the battery and lift. The plastic opening tool will be the best tool for this.
    • It is possible that the battery may be glued onto the phone. If this is the case, slightly heat the glue to allow removal without breaking the battery. To heat the glue, use a simple hair dryer, but be very careful as not to overheat the phone and damage any components.
结论
3等其他人完成本指南。
Cary Drew
于09/25/14注册
866 声望
创作了5篇指南
团队
USF Tampa, Team 1-1, Brown Fall 2014 USF Tampa, Team 1-1, Brown Fall 2014 的会员
USFT-BROWN-F14S1G1
4 名成员
创作了5篇指南
3条评论
Thanks, battery successfully changed :-)
martinslunecko - 回复
Thanx will do that when i get areplacement battery!
ndiwenijb - 回复
hello where i can find a new battery ?
minigamer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,230
