跳转到主内容
修复你的物品
维修的权力
商店
简介
This is the step-by-step guide for replacing the Sony Xperia M4 Aqua rear camera.
  1. Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound. While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove  carefully, as it has the potential or tear if too much force is used.
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Remove the battery once all of the adhesive is broken, and the connector is unplugged.
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
  9. Remove the four hex head 3mm screws at each corner of the motherboard with a screwdriver.
    • Remove the four hex head 3mm screws at each corner of the motherboard with a screwdriver.
  10. Remove three pieces of the securing bracket using tweezers Remove three pieces of the securing bracket using tweezers
    • Remove three pieces of the securing bracket using tweezers
  11. Detach the rear camera connector from the front of the motherboard. Remove the rear camera with your fingers or tweezers.
    • Detach the rear camera connector from the front of the motherboard.
    • Remove the rear camera with your fingers or tweezers.
    Isn't front camerra?
    bambang purnomo - 回复
结论
4等其他人完成本指南。
Sarah Wetzler
于2016年02月10日注册
478 信誉积分
创作了2篇指南
团队
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016 的会员
USFT-LACY-S16S4G5
3 名成员
创作了8篇指南
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - 回复
That's the front camera. You have the front and rear camera mixed up!
mivanchev - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 9
总计 3,353
