跳转到主内容
Sony Xperia M4 Aqua Back Cover
你所需要的
  1. Sony Xperia M4 Aqua Back Cover, Back Cover: 步骤 1 中的图像 1,1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Back Cover: 步骤 2 中的图像 1,1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Back Cover: 步骤 3 中的图像 1,2 Sony Xperia M4 Aqua Back Cover: 步骤 3 中的图像 2,2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Back Cover: 步骤 4 中的图像 1,1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
结论
17等其他人完成本指南。
Brian McKalip
于02/10/16注册
2,112 声望
创作了2篇指南
团队
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016 的会员
USFT-LACY-S16S4G5
3 名成员
创作了8篇指南
3条评论
Thanks. Do you know where to order a new back cover? Mine has shattered
Michael McNicholas - 回复
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - 回复
Reassembling just in reverse order you’ll  get a non-dust and non-waterproof device and not normally fixed rear cover.  You have to apply special Sony Xperia M4 Aqua E2303 Adhesive Sticker, 56BTUL0030A.
Andrey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 8,226
