跳转到主内容
Sony Xperia L2 LTE Motherboard Replacement
你所需要的
  1. Sony Xperia L2 LTE Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Sony Xperia L2 LTE Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Motherboard Replacement: 步骤 2 中的图像 1,3 Sony Xperia L2 LTE Motherboard Replacement: 步骤 2 中的图像 2,3 Sony Xperia L2 LTE Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Motherboard Replacement: 步骤 3 中的图像 1,1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Motherboard Replacement: 步骤 4 中的图像 1,2 Sony Xperia L2 LTE Motherboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Motherboard Replacement: 步骤 6 中的图像 1,3 Sony Xperia L2 LTE Motherboard Replacement: 步骤 6 中的图像 2,3 Sony Xperia L2 LTE Motherboard Replacement: 步骤 6 中的图像 3,3
    • Use blue plastic opening tool to pry off the motherboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 474
