跳转到主内容
Sony Xperia L2 LTE Charging Port Replacement
你所需要的
  1. Sony Xperia L2 LTE Charging Port Replacement, Battery: 步骤 1 中的图像 1,2 Sony Xperia L2 LTE Charging Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Charging Port Replacement: 步骤 2 中的图像 1,3 Sony Xperia L2 LTE Charging Port Replacement: 步骤 2 中的图像 2,3 Sony Xperia L2 LTE Charging Port Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Charging Port Replacement: 步骤 3 中的图像 1,1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Charging Port Replacement: 步骤 4 中的图像 1,2 Sony Xperia L2 LTE Charging Port Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,2 Sony Xperia L2 LTE Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to lift the charging port circuit board.
  6. Sony Xperia L2 LTE Charging Port Replacement: 步骤 6 中的图像 1,1
    • Unhook the antenna from circuit board using a plastic opening tool and remove the charging port circuit board from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 625
