简介
You will be shown how to take apart your phone successfully up until you get to the piece you would like to change. Then you will be shown how to replace the desired part.
The battery should be removed before working on the phone internals.
你所需要的
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Once the silver plate has been detached from the phone, locate the speaker at the bottom of the silver plate.
Insert the tweezers' tip into the small hole located at the left side of the speaker. Once the tip is inside, just remove the speaker from left to right.
Place the new speakers in the same spot as the old one, and then push it with your finger until you hear a click.
另外一个人完成了本指南。
