跳转到主内容
Sony Xperia J Speaker Replacement
你所需要的
  1. Sony Xperia J Speaker Replacement, External Features: 步骤 1 中的图像 1,1
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
  2. Sony Xperia J Speaker Replacement: 步骤 2 中的图像 1,1
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
  3. Sony Xperia J Speaker Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
  4. Sony Xperia J Speaker Replacement: 步骤 4 中的图像 1,3 Sony Xperia J Speaker Replacement: 步骤 4 中的图像 2,3 Sony Xperia J Speaker Replacement: 步骤 4 中的图像 3,3
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
  5. Sony Xperia J Speaker Replacement: 步骤 5 中的图像 1,3 Sony Xperia J Speaker Replacement: 步骤 5 中的图像 2,3 Sony Xperia J Speaker Replacement: 步骤 5 中的图像 3,3
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
  6. Sony Xperia J Speaker Replacement: 步骤 6 中的图像 1,1
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
  7. Sony Xperia J Speaker Replacement: 步骤 7 中的图像 1,1
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
  8. Sony Xperia J Speaker Replacement, The Speaker: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once the silver plate has been detached from the phone, locate the speaker at the bottom of the silver plate.
    • Insert the tweezers' tip into the small hole located at the left side of the speaker. Once the tip is inside, just remove the speaker from left to right.
    • The speaker might be a little difficult to remove due to the glue used when assembling the phone.
  9. Sony Xperia J Speaker Replacement, Replacing the speaker: 步骤 9 中的图像 1,1
    • Place the new speakers in the same spot as the old one, and then push it with your finger until you hear a click.
    • Remember that the letters written in the speaker should be upside down before inserting the replacement.
结论
另外一个人完成了本指南。
Arlind
于01/21/15注册
899 声望
创作了5篇指南
团队
USF Tampa, Team 4-3, Brown Winter 2015 USF Tampa, Team 4-3, Brown Winter 2015 的会员
USFT-BROWN-W15S4G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,074
